Release 4 is out
A project log for 4000 Series Logic Reference Cards
Mid-70s CMOS called and wants the past dues
kuba-sunderland-oberKuba Sunderland-Ober 01/25/2024 at 22:130 Comments
Since each reference card has its own revision, it doesn't make sense to call a release "revision". This is the 4th release, and it contains a mix of sheet revisions.
Sheet revisions in this release are listed below, one numbered sheet per entry.
  1. rev 2
  2. rev 3
  3. rev 3
  4. rev 3
  5. rev 2
  6. rev 3
  7. rev 2
  8. rev 2
  9. rev 3
  10. rev 3
  11. rev 3
  12. rev 3
  13. rev 4
  14. (unnumbered bonus sheet) rev 0
Index pages i through viii are "fossil revision", without a revision mark.
Changes:
  1. All active-low input and output pins have an inversion circle. Previously only some pins had the inversion circle. Pages affected: 4, 6, 9, 10, 11, 12, 13
  2. Fixed CD40110 LE pin/signal logic. It is now correctly marked active-low. Page 13.
  3. Fixed CD4511 LE pin/signal logic. It is now correctly marked active-low. Page 10.
  4. Fixed CD4543 LE pin/signal logic. It is now correctly marked active-high. Page 10.
  5. Added legend for the meaning of LE signals on page 10.
