4-bit cpu schematics 1.2
A project log for The simplest 4-bit RISC CPU
In this project, I built a very simple 4 bit RISC CPU. *Sponsored by PCBway
marsianin245Marsianin245 06/14/2023 at 01:390 Comments
I realized that the flip-flop chip 74LS173 is obsolete and no longer available.
Replaced the obsolete 74LS173 with other TTL flip-flop 74LS175.
Added jumper and switch for manual step clock operation,
Added 5v voltage regulator and bypass capacitors.
The new schematics revision 1.2
