Water and Gas Meter Reading Demo + New Issues
A project log for YDrip
An open source water meter that detects leaks and measures usage
ydripydrip 09/27/2023 at 18:300 Comments
Quick update on the status of V3 testing. Water and gas meter reading works. DC offset calibration is working well. The only new issue is the metallic housing on the AA batteries is causing significant interference with the mag sensor. Enough that it saturates the sensor beyond the offset calibration capabilities. I will either need to redesign the PCB and case to add more distance between them or switch to a different battery technology.
