Minor successful step
A project log for Atomic Force Microscope - from ground up
The aim of this project is to make high grade all diy AFM.
100dollarhacker100dollarhacker 06/14/2023 at 03:200 Comments
The next step is to use Quartz fork. I've bought sime 2x8mm 32KHz Quartz oscillators. Now the tricky part is to gently remove enclosed without breaking the Quartz fork. I've preferred to use small file to remove metallic encapsulation. (Although it's tempting to put Quartz fork into something like a drill, I was afraid that centrifugal force will damage this tiny fork)
