I ordered the parts for the 3.1 XPE2 version in September 2021 in July 2022 the last part finally arrived. I intended to make 10 TritiLEDs, so I ordered 11 of every components and some extra of the cheap ones like resistors and capacitors. I ordered the PCB and the stencil from a local PCB shop. I ordered the PCB three times, since it was the minimum amount. An electronics shop nearby was closing down, so I used the opportunity to get some solder paste and say goodbye. Now finally I have everything I need!
