Direct geared pellet Extruder for PLA in a compact easy to manufactureable way. Project is almost finished, was halted due to motivation shortage.
Technically a necessary piece of equipment as protoyping produces quite a bit of wase that doesnt get recycled or bio-degraded.
Should deliver usable prints with 1mm nozzles at a 40 mm/s speed.
Last status was a short on the stepper driver because the mechanical decoupling of the wire got loose. Build a new "shovel mechanism" that feeds flakes more contastant.
Most likely will be continued this year, depends on sudden motivation.
