Toggle pattern for frequency response
A project log for Raspberry Pi Pico Super Simple Oscilloscope
Raspberry PI and ADC10080, works decently for a 24 Mbps signal and has 100 k input impedance
sciencedude1990sciencedude1990 06/17/2023 at 03:290 Comments
Next, I changed the PIO from bit pattern, to toggle.  So, a 2 MHz toggle gives a 1 MHz signal.  Here is the response that I measured.  So, a 3 dB frequency response of roughly 10 MHz.
So, for ~$50 CDN in parts, you can have a 96 MSps, 10 MHz scope with 100 k input impedance.
