• 1
    Step 1:
    Cut your fabric to size for all bag components. In this case, the main body of the bag is 42x55cm and the flap x2 measures 42x30cm.
  • 2
    Step 2:
    Sew the body panel of the bag. First create a seam for the top and bottom of the sheet, and the fold it in half to create the volume of the bag. Once the seams are complete, the bag can be turned inside-out to hide the seams. (Optional - hide the seams with additional nylon, or add a bag liner)
  • 3
    Step 3:
    Sew the top flap 42x30cm for the bag by cutting a opening in the first panel 23x13cm for the solar panels to be displayed and add seams to all four sides. Then add the second alternative color back nylon panel and add a seam around all four sides. Then turn the entire flap inside out, and stitch the solar panel into the window.
