Stop Water Flow:
A project log for PrecipitatePause: An Automated Rain-Driven Water C
An easily installable device that is placed on people’s sprinklers that has the ability to save 400 billion gallons of water each year.
tyler-carmelTyler Carmel 07/02/2023 at 23:190 Comments
We decided that we would use a shut off valve that would be turned to turn off the water.
``Picture of shut off valve``
Then put a servo with a star shape that could turn the shut off valve handle 0 to 80 degrees.
‘’Picture of servo on shut off valve’’
The user would put in where they live, what time their sprinkler turns on, and how long it stays on.
This data would be processed by python and output yes if there was rain or no if there wasn’t.
Then the C++ code that was already on the arduino would receive what the python had said, if it was a yes then it would tell the servo to turn 80 degrees and lock for however long the user inputted. Once that cycle was done the python code would once again check the weather and say an output to the arduino accordingly.
We make the set up for the user because the whole device can just be screwed on the spigot on one side then the other side will just be the hose that is connected to the person’s sprinkler system. Then they just have to open up our website then fill in 3 boxes, where they live, what time their sprinkler turns on, and how long it stays on.
