ESP 32 Code upload
A project log for UltraTower 2023
Grow vegetables with ultraponics tower
j-gleyzesJ Gleyzes 07/04/2023 at 05:270 Comments
I have updated the code on github for the new PCB.
In this new version there is :
The entire bluetooth communication routine between an android smartphone and the esp32 is also complete.
This application, which should arrive this week, will allow you to modify the parameters of the tower (such as the time of the cycles, activate or deactivate the sensors, ...)
But most importantly, the EC and pH sensors can be easily calibrated through the application.
