• 1
    Unpack your kit
    Each kit comes with the following items included:
    1 - Stuffed plushie
    1 - 3mm red LED
    1 - 3mm green LED
    1 - 3mm blue LED
    3 - Red wires
    3 - Blue wires
    2 - 499ohm resistors
    1 - Battery holder
    2 - CR2032 batteries
  • 2
    Remove stuffing
    Remove the stuffing from the plushie and set aside.
  • 3
    Push LEDs through
    Push each LED through the corresponding square on the top of the plushie. Be sure to support the LED legs when pushing through so they don't bend. Make sure that all LEDs are facing the same direction. Once all LEDs are through, turn the plushie inside out.
