Project log # 11 "tears of mediocracy"
A project log for Home Biology Lab
A diy bio lab for mammalian cell culture, genetic engineering, and whatever creations cross my mind
saporanoSapoRano 09/02/2023 at 02:520 Comments
Okay Okay Okay
so I need to slow down a little
the plan is still
1. grow E.coli
2.express gene in E.coli
3.do same thing in agrobacterium
4.culture plants
5.modify plants
now I'm making a list for steps one and two focusing on one so now I need the BARE basics so what do I need to grow E.coli?
I have a list currently but hackaday is stupid and I can't upload files so I'm just gonna copy paste
NameCo stQuantityDIY/BUYLinkNotes
Pipette kits$99.001BUYhttps://www.amazon.com/dp/B0B8165PTL/?coliid=I1BNMZAA5ATL36&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itcheap and reliable
Microcentrifuge 10krpm 1.5ml$98.991BUYhttps://www.amazon.com/dp/B0B2RMG25F/?coliid=IMNKJ5TSDBPPC&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itno way in hell im DIYing this
centrifuge 4000rpm 15ml$60.001BUYhttps://www.amazon.com/dp/B0176D9QFS/?coliid=ILAD005R0EJ79&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itsame as above
autoclave (pressure cooker)$49.951BUYhttps://www.amazon.com/dp/B07RN9D69J/?coliid=I1DPAAEEE826XH&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itsame as above
Incoluating loop$8.991BUYhttps://www.amazon.com/dp/B079TNFHT4/?coliid=I3P3Y8F3HAPLCR&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itcheap and reliable
microcentrifuge tube$18.9910,000BUYhttps://www.amazon.com/dp/B00577ZQH8/?coliid=IKQTZFWH9YD89&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itimportant
glass vials$5.7312BUYhttps://www.amazon.com/dp/B002JV89OC/?coliid=I12J1M548YLF1N&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itfor agar stabs
15ml tools$18.99100BUYhttps://www.amazon.com/dp/B0BQZ8LK1H/?coliid=I3IBP950XAMJ0U&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itimportant
syringe filter$28.69100BUYhttps://www.amazon.com/dp/B0BK8M7GXT/?coliid=IU5TG3627WPCM&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itimportant
syringes$13.49100BUYhttps://www.amazon.com/dp/B07BQFTHMQ/?coliid=I1CU9J2R40AJK8&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itimportant
erlenmeyer flasks$19.996BUYhttps://www.amazon.com/dp/B09VNYZ1TP/?coliid=I3B5KH5U8DAZ1G&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itgotta make media somehow
autoclave tape$24.905BUYhttps://www.amazon.com/dp/B097BVYGHC/?coliid=I1SWOLH523UFVO&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itclean yes
uvc bulb$20.991BUYhttps://www.amazon.com/dp/B0B1M8JXCY/?coliid=I4C5FLLQV5CXY&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itclean yes
torch$14.971BUYhttps://www.amazon.com/dp/B07FFNKQVD/?coliid=I2X0D5NFR5S2IA&colid=2ST2U496V3HDN&psc=1&ref_=list_c_wl_lv_ov_lig_dp_itclean yes
Heat block$35.001BUYboughthot
cold shock$10.001DIYmadecold
refrigeratorFREE1FOUNDFOUNDcool yes
freezerFREE1FOUNDFOUNDvery cool yes
Gel Electrophlorisis~201DIYdiyjust gonna use a dc power supply to make pretty easy
>td >?1DIY/BUY not surediyhave no idea maybe ebay maybe diy
microscope 40-1000x$78.991BUYhttps://omaxmicroscope.com/collections/compound-microscopes/products/xg619blook small yes
gene gun~1001DIYdiy found a couple guidesounds cool and fun
clean space~not sure1DIYhttps://hackaday.io/project/191938-home-cell-culture-lab/log/222457-project-log-9-its-all-comin-togethergo over to hackaday to catch up with plan have somthing in the works
total$607.66
Okay so I just need something to sanitize them something to grow it in and something to freeze them in
Just those steps
I'm going to make a new list for the tools required just to do those
Pipette kits
Autoclave
inoculating loop
bunsen burner
petri dishes
incubator
LB Broth
agar
glycerol
So from this list I have the Incubator and the petri dishes
Of course I will be needing other reagents but those are the most important
The plan is to use a bunsen burner to generate a aseptic area for culturing cells in the beginning just for startup but
But I gotta stop procrastinating I don't know why but my brain just want to push it away as hard as it can no matter what I wish I knew why
Now for the reagent LB broth is Extremely cheap to mix your own and glycerol is also extremely cheap
The biggest cost here is the autoclave and micropipettes I need to get those down as those will be important now and In the future
I need to get something done
Also I found a new discovery while fishing for treasure in the garage a old food heater the kind that was meant for keeping things warm for long periods of time and it could possible be used as a new incubator
It would work and is made out of metal and glass so it would look good too but who am I kidding I need to stop wasting my time and getting something done already
School has just been sucking up all of my time
Right now I need help picking an autoclave this is very important as having an aseptic working area and technique is key to making any of this work
I need help right now in picking an Autoclave as It will be key I might just settle for a pressure cooker right now and spend a little more money later on for a slightly nicer one once i've made some friends
That's it for now I will give another update soon
Peace
