Project costs
A project log for Programmable Precision Resistor
A SCPI programmable precision resistor
sebastianSebastian 09/11/2023 at 15:270 Comments
I didn't really think about the BOM cost of my programmable decade resistor until I was asked. Then I also wanted to know. It is fairly difficult to put a number to what I paid, since I had a lot of components left from other projects that I could use. This includes not only cheap chip resistors and MLCCs, but also connectors, the microcontrollers etc.
Normally, I order my parts from mouser and digikey. For some of the industry-standard components, connectors etc. I also use local distributors (cheaper!). This is why I'll only give a very rough estimate for the per unit costs including taxes (and not including any shipping costs). For some of the parts like the PCBs there is a minimum order quantity that will increase the cost in most DIY scenarios.
Mechanical parts
#Description€ (est.)
1ELMA Stylebox 15 Standard (not new)50,00
2Front & Rear panels (Aluminum PCBs)5,00
3Rotary encoder knobs and key caps10,00
4IEC power connector + Fuse3,00
54mm banana sockets8,00
6Connectors, cables etc.2,00
7Mounting hardware2,00
80,00
Mainboard
1Mainboard PCB3,50
2STM32G441KBT66,50
3EC2-12NU relays (or similar)73,50
4Precision resistors63,00
5Other components30,00
176,50
UI Board
1UI PCB2,50
2STM32L0102,00
3STP16CP05 constant current LED drivers10,00
4LED displays15,00
5Rotary encoder and switches37,00
6Other components12,00
78,50
Power supply board
1Power supply PCB1,00
1TRACO TMPW 10-11519,50
1NE-18 series power switch8,50
1Other components5,00
34,00
Conclusion
According to this calculation the total cost of the unit would be about 369 €. Quite a lot, actually. This doesn’t necessarily reflect what I paid for it though. One example: I bought 5 NE-18 type switches on ebay for about 2 € each. These are not necessarily the same as the ones provided by mouser, but both variants could be used.
