Final Bill Of Materials
A project log for SNOWBYTE
Open-Source RC Snowplow that can remove snow from your driveway or sidewalks and can be customized for other tasks around your home.
cele9999cele9999 10/07/2023 at 20:060 Comments
BOM:
PartNumberCost of each part
Power Supply1$22
Linear Rails1$60
Linear Actuator1$50
Bracket Connectors (12 PCS)1$16
Motor Driver1$16
15A Fuse Holder (10 PCS)1$8
15A Car Fuse (20 PCS)1$5
Power Socket1$8
DC Motor (with sprocket)2$44
#25 Bicycle Chain2$17
Roller Chain Detacher1$10
Gauge 14 wire (200ft)1$15
#25 Chain Sprocket2$13
Polycarbonate Sheet (1/4”Thick x 24”Wide x 36”Long)1$47
6 Channel RC Transmitter and Receiver1$37
1/2" Bore Shaft Collars (4 PCS)3$10
#25 Chain Connector Link (10 PCS)1$10
#4-40 Hex Nuts (100 PCS)1$2
#4-40 x 3/4" Phillips Screws (100 PCS)1$9
Snow Shovel1$12
Perf Board (10 PCS)1$5
12V Regulator (20 PCS)1$7
1/2" x 3' All threaded rod (5 PCS)1$30
1/4" x 1' All threaded rod1$10
1/2" Hex Nuts (50 PCS)1$10
1/4" Hex Nuts (50 PCS)1$8
Lawnmower Wheels (2 PCS)2$14
Arduino Nano1$6
Jumper Wires Female-Female (120 PCS)1$7
Male Header Pins (20 PCS)1$5
Insulation Tape1$7
Assortment Kit (200 PCS)1$7
Loctite1$10
Final Price for the entire project=$645
