'Finished' Prototype
A project log for The Resistorganizer
Managing resistors is a chore. Well, with the Resistorganizer, you can just jam your loose resistors into a breadboard and be done with it.
mikeMike 09/05/2023 at 16:400 Comments
Forced to the Ground:
After some debugging, head-scratching and swearing I couldn't find the reason why the enable pin was being held high on the HC595 shift registers when more than two registers were populated on the board. Eventually I gave up and measured the current flowing from the enable to ground, saw that it wasn't too much, and bodged in a 11k pull-down resistor to an adjacent chip's ground and called it good.
What Next?
I would like to fix / do the following:
When Will That Happen?
Honestly, I don't know. This project started with me feeling stuck in my workspace because organizing is a chore. Now that I have The Resistorganizer, I have what I want and (selfishly) that's what is important to me at the moment. This was always intended to be a tool rather than something I'd turn into a product for release. Nevertheless, I do want to share my work, so that anyone can take it an build their own or run with it. So, I'll revise the schematic to the best of my ability, but beware, there be bugs. Once I have it in a condition I feel comfortable sharing, I'll put them in this .io project.
THANK YOU!
This is my first project on Hackaday.io and I want to express how rad I think this community is and say thanks to all who provided insight and encouragement. I learned a lot from this project and a lot of that came from you. Cheers.
