Refine PCB layout with V1.1
A project log for PicoPD - USB-C PD 3.0 PPS Trigger with RP2040
Adding Power Delivery 3.0 (PD3.0) & PPS to our beloved RP2040 chip in Pico footprint.
centylabCentyLab 09/28/2023 at 06:530 Comments
Learning from the previous design, I have made some changes to the layout while keeping the schematic the same. Here are some main changes:
The next October 25th,2023 batch will be V1.1. You can make your own using the provided Gerber, else you can support me through Tindie PicoPD.
