Update on AP33772 Library
A project log for PicoPD - USB-C PD 3.0 PPS Trigger with RP2040
Adding Power Delivery 3.0 (PD3.0) & PPS to our beloved RP2040 chip in Pico footprint.
centylabCentyLab 03/13/2024 at 04:560 Comments
Originally, the PicoPD would require the user to unplug and replug in from the charger after uploading new firmware to request the power profile again. This mundane task can be annoying if you are actively adjusting a small part of the code.
Thanks to Patrick, the AP33772 library can now request PDO profiles after a new firmware upload. Changes has been reflected to AP33772-Cpp Repo.
