Entry #6: Introduction to Hyperion II
A project log for Raspberry Pi Zero rocket camera
A budget action camera made with a Raspberry Pi and a Rockit flight computer to shoot 1080p video from a water rocket.
danielDaniel 01/25/2024 at 07:380 Comments
The Raspberry Pi rocket camera project will need a rocket. For this purpose, I have started the construction of Hyperion II. Hyperion II will be a fiberglass-reinforced water rocket capable of operating at pressures up to 12bar with a peak thrust of 15kg.
At the moment, I have spliced the two pressure chambers, 3D printed the coupling that allows me to connect them as well as 9.5mm nozzles. Here is a short video showing the construction progress.
