Pi Extension board "PiEBridge" adapters
A project log for PCB Assembly Desktop Factory
Creation of ready-made low-budget infrastructure for developing, manufacturing, and adjusting electronic devices
teardownitteardownit 12/28/2023 at 15:470 Comments
Programmable power supply for external/target devices
The PiEBridge has a built-in programmable power supply for external/target devices. The user can set the voltage of 2.5-5V (accuracy not less than 2%) with a current not more than 300mA by command from SBCs (e.g., Raspberry Pi).
Users can set this programmed voltage or "ground" to any pin of the output connectors using the built-in 3*10 pin matrix and jumpers.
Connectors
The PiEBridge extension board has built-in 6-pin IDC (2x3 0.1") and 10-pin IDC (2x5 0.1") output connectors.
We recommend using four basic adapters to connect to target systems (e.g., for flashing) via these connectors:
IDC6-IDC6
IDC6-TC2030
(Tag Connect 6 pins)
IDC10-IDC10
IDC10-TC2050
(Tag Connect 10 pins)
Analogs in Segger adapters
PiEBridge adapterConnects to:Segger adapter
IDC6-TC2030PCB pads, no mating connector required on PCB
Users who do not use any standard for
connector pinout can program all chips
with compact programming interfaces
having 6 or fewer circuits - SWD, SWIM, SPI, etc.
6-Pin Needle Adapter
IDC10-IDC10the 10-pin 100-mil Intel FPGA JTAG connectorIntel FPGA Adapter
(formerly J-Link Altera Adapter)
---Silicon Labs evaluation boardsSiLabs C2 Adapter
---the SWIM connector and a standard 10-pin connector (STM8)STM8 Adapter (IDC10)
IDC10-TC2050PCB pads, no mating connector required on PCB10-Pin Needle Adapter
