JLC-PCB specific manufacturing docs available
A project log for FindMyCat - The Open Source Pet Tracker
The only pet tracker you will ever need. Months long battery life, works outdoors and indoors. It’s Purr-fectly Empowered.
sahas-chitlangeSahas Chitlange 10/08/2023 at 18:230 Comments
I found that a lot of people in the FindMyCat Slack were using JLC PCB for their PCB manufacturing needs so I added some manufacturer specific detailed documentation in hopes to make the fabrication of FindMyCat PCB boards little bit smoother.
Please check the guide here: https://www.findmycat.io/docs/CircuitBoard/JLCPcbManufacturing
Note that this is not sponsored by JLC at all.
