register your beacon on Alphatango
A project log for Variometer + GPS tracker + remote_ID for RC glider
ever wanted to add a variometer to your glider ? ever wanter to add a GPS tracker to find your plane when crashed ? and a remoteID beacon ?
jp-gleyzesJP Gleyzes 09/15/2023 at 16:490 Comments
Your beacon has a unique code and must be registered into the French UAV platform "Alphatango"
First you will have to choose 3 letters havinf a "meaning" for you ! In the code it is "TRI"
   MODIFIEZ LES VALEURS ICI
// Set these to your desired credentials.
const char ssid[] = "TRI01_droneID"; //Le nom du point d'acces wifi CHANGEZ LE par ce que vous voulez !!!
const char *password = "your pass";     //Mot de passe du wifi
//IMPORTANT --> CHANGEZ l'ID du drone par celui que Alphatango vous a fourni (Trigramme + Modèle + numéro série) !
const char drone_id[] = "000TRI000000000000000000099991";
Now that you have choosen an Id you have to check if it is a valid one AND a not already used one...
The solution is to "register a new plane" on the french Alphatango.
You have to tick the box has shown and enter twice the ID you have choosen.
Now click on "save" button and it's done. If success then the ID was free. If it fails choose another one !
