The earth is a magnet :-)
A project log for Galaxy6D: simple DIY full 6D space mouse
Full 6D mouse by three 3D magnetic sensors and magnets. 3D printed housing, ESP32S with battery operation over BLE as well as USB-C.
bastelbausBastelBaus 10/14/2023 at 21:090 Comments
I did some calibration measurements by rotating the knob only in one direction and doing a principal component analysis just using the first component for each of the measurements as a projection matrix
Not directly visible but I can tell you the first component (yaw) worked very nice. The plot was highly correlated to my movement of the know. When the other come in play, I recognized that there was a lot of cross talk. Then I recognized that the signal change when I move the whole know around the space ... oh yes earth magnetic field .... damn ... I plotet the raw signals from the simulation and recognized that the signals had also been in the range of the earth magnetic field (about 0.05mT):
So how to solve it, in principle I have 9 measurements and 9 degrees of freedom (3 rotation and 3 displacements of the know respectively and 3 of the magnetic field). OK, since my sensors are not on the same position, one could argue that I even have 6 degrees of freedom of the whole device in space. How to continue:
