Power balancing
A project log for Mini solar with AC backup & monitoring
A petite solar installation to achieve grid independence for a segment of your dwelling. Last log about a voltage hysteresis on Nov 7th '23.
guidoGuido 10/20/2023 at 18:040 Comments
In a sunny day, at noon my single solar panel can supply no more than 110W and 20-30W if cloudy.
The appliances I connected (2 PCs, 1 32" monitor, 1 network switch, 1 LED lamp, two mobile phone chargers) need between 50 (1 PC in stand-by ad the monitor off) and 120 W.
Therefore, even during the sunlight (120 > 110) the solar panel cannot charge the battery 🙁.
So I decided to buy another solar panel to get 220W when sunny and 40-60W when cloudy. I'll let you know!
Bye
