Progress 26.12.2023
A project log for Puppet War - Alternative Controllers
Using an alternative controller, become a master puppeteer and play the game gang beasts against your friends
luispoujolluis.poujol 01/09/2024 at 14:020 Comments
Finished soldering and received box to hold the sensors. Also made a handle to pull on the pressure sensors and finished connecting all 4 sensors with their cables to the arduino. This required a common VCC, GND and SCK (clock) pin with different DT pins for each sensor.
Working on the code to get the 4 readings with each sensor and also to make sure we get 'w' 'a' 's' 'd' readings when a specific sensor is pressed.
