Well It almost worked
A project log for 3D Printed Chiming Clock
A 3D printable clock that uses a train of marbles to strike the hours
wooddragon48wooddragon48 11/04/2023 at 21:230 Comments
I printed a copy of the Escape Wheel and the Graham Yoke to test how well it would work. Well it mostly worked, but would occasionally hang up, and was quite rough in spots. So I decided to go back to basics and redesign both the Yoke and the Escape Wheel. This version of the Yoke has adjustable pallets, and the Escape Wheel has a negative rake on the teeth to provide relief to the pallets as they over travel. With regards to the Yoke over travel, this design allows for three to four degrees of over travel in each direction. As this a Graham Yoke the escape wheel is held stationary while the Yoke over travels with the pallets just sliding along the tip of the Escape Wheel tooth. This hopefully means that I can sand the striking and sliding surfaces along with the tips of the Escape Wheel teeth to make the operation smooth and quite. With adjustable pallets it is possible to setup the Yoke so that the inactive pallet is in position to block the next tooth on the Escape wheel just before the impulse portion of the cycle is finished.
To help visualize and verify the design I did a quickie Python script to animate the escape operation
Upper pallet detail.
Lower Pallet detail.
Now I just need to print the new parts and see how well it works. I will up load the new design to replace the not so good ones.
And Just because I think It looks cool, here is the animation in an isometric view.
I updated the ZIP file to have the new Yoke and Escape Wheel, a few changed files that were fixed to make them easier to print, and the Back Frame parts that need to change to accommodate the new thicker Yoke design.
