poor man's pyranometer
A project log for 1Charger
OneCharger to rule them all; solar-panel, TEG, dynamo...
mrjbmr.jb 07/04/2015 at 06:030 Comments
Most lux sensors has a limited range ( < 100 000 lux ) and I plan a different approach.
Current source current is directly proportional to the solar radiation
Measuring Solar Radiation, Chuck Wright
Measuring Solar Radiation by Chuck Wright
In a solar cell, the parameter most affected by an increase in temperature is the open-circuit voltage -2.2 mV/°C
The short-circuit current, Isc, increases slightly with temperature, since the band gap energy, EG, decreases and more photons have enough energy to create e-h pairs. However, this is a small effect and the temperature dependence of the short-circuit current from a silicon solar cell is
A change form 25 to 50 °C will increase Isc current 1.5%.
The impact of increasing temperature is shown in the figure below
Area [dm²]Isc [mA]Lux0.000079 x lux [Watt/dm²]
0.71 ( 1W panel ) 185.51200009.48
152 935007.39
129764006.03
20.9 143001.13
3.1 ( 5.15w panel )10101195009.44
850 954007.54
730765006.04
610588004.65
5.7 ( 7.5watt panel )15601132008.94
1390 960007.58
1170762006.02
1040611004,83
http://www.pveducation.org/pvcdrom/solar-cell-operation/short-circuit-current
http://www.pveducation.org/pvcdrom/solar-cell-operation/effect-of-temperature
Pyranometers and reference cells
Pyranometers and Reference Cells, What’s the Difference ?
