Overview
Arduino wifi shield connects the Arduino with a wifi chip through the serial communication pins. so that, we can perform different IOT projects using Arduino and this Board.
FOR FULL PROJECT:
https://electronicsworkshops.com/2023/11/28/how-to-design-own-arduino-wifi-shield-pcb/
Introduction
In a general sense, an Arduino WiFi shield PCB would likely be a printed circuit board designed to provide wireless communication capabilities to an Arduino microcontroller. The design would typically include components for WiFi connectivity, such as an integrated WiFi module or chipset, antenna connections, and possibly additional circuitry for power regulation and signal conditioning.
Description
An Arduino Shield that allows you to prototype Arduino Wifi projects. It used Pin2,3 and Pin9,10 for Software Serial (Jumper Selectable). It can external power (9VDC) or be powered by the Arduino or from an FTDI Adapter.
  1. FTDI Adapter must be switched to 3V3.
  2. FTDI Adapter is used to Program the ESP01S.
  3. Arduino is programmed through its USB OnBoard.
  4. Arduino can also supply 3V3 to the ESP01S.
  5. Power Jumper is used to switch power between ARD/FTDI and External Power.
Bill Of Materials
Edit
SNCOMPONENTS NAMEDESCRIPTIONQUANTITY
1Arduino UNOREV31https://amzn.to/3R3s9pr
2Connecting wiresjumper wiresomehttps://amzn.to/3fMoSw7
3BreadboardNormal1https://amzn.to/3FUQlXe
4ESP8266Serial wifi module1https://amzn.to/40Yyh73
5Resistor PackSHT401https://amzn.to/47TIoMH
6Capacitor PackSPS301https://amzn.to/4a16VkQ
7LED packMiCS55241https://amzn.to/47YQMdV
8Voltage Regulator5 volt / 3.3volt1https://amzn.to/3uEjEcT
Schematic Diagram
Schematic_Wifi-Shield-Prototype_2023-11-27-1Download
PCB Diagram
3D Diagram
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own  Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
ORDER IT DIRECTLY FROM PCBWAY*******
FOR FULL PROJECT:
