First run
A project log for CNC Micro coil winder
Small coil winder built from cheap import components with 3D printed structure.
marsupilamiMarsupilami 12/10/2023 at 20:310 Comments
First run:
I couldn't find anything good to wind on. It starts well for the first 10 turns or so then skips and then is all messed up.
The movement in the background is the backlash compensation nut on the X axis. (Needs adjustment)
The noise is from the wire spool rattling on the makeshift axle, not coming from the machine.
Overall not too bad. I'm sure it could be made better with enough tweaking.
