Either a pinout problem, or a sensitivity issue
A project log for First steps with the RCWL 0516 radar switch
How to power up and communicate with the cheap RCWL-0516 radar sensor module
ivorasivoras 01/19/2017 at 19:593 Comments
The module's OUT line was high too often, as if it has a huge amount of noise, so I Googled a bit and found a video by a Russian guy, who only connects the VIN, OUT and GND, ignoring the 3V3 pin. So I've also done that, connecting VIN to 5V, and it *seems* to be more stable. I'll leave it running for a while so I'll collect more data. If someone knows Russian enough to verify what he was doing, please write up some info in the comments.
Matt H wrote 01/06/2018 at 06:12 point
Lots of information at https://github.com/jdesbonnet/RCWL-0516, most importantly that VIN is the supply voltage for the board, 3V3 is an output, and OUT is a logic (3.3V) output when triggered.
petermeier73 wrote 01/19/2017 at 21:39 point
 My English is not so good, so sorry if i didnt write something really well, i try it :)
He describe the Chip. This chip is using for Safety implement like in doors, infra-red, audio surveillance...
davedarko wrote 01/19/2017 at 20:37 point
I have no clue what he's saying, but having automatic, translated subtitles on is quite funny
