Working on the electronics
A project log for YABDT - Yet another barn door tracker
How to build a barn door tracker - using a trapezoid threaded rod, a stepper, some phenolic plywood and a bunch of electronics.
mughtywinkyMughtyWinky 01/19/2017 at 13:400 Comments
Actually I am working on the electronics, which will control the stepper. As the "barn door" parts will be ready this weekend, the electronics should at least be able to drive it for a quick test.
A Finite State Machine will be used to control the whole thing. Two push buttons should allow enough interaction. These states are implemented:
Pressing both buttons simultaneously will switch between auto and manual mode. Pressing one of the buttons will either move the barn up or down. Below you find a quick snap of my (really messy) workbench.
