Byte Order in the ASCII HEX Files Corrected
A project log for PicoRAM 6116 - SRAM Emulator & SD Card Interface
Give your Microprofessor MPF-1B (and other machines) a versatile SD card interface - no more cassettes!
michael-wesselMichael Wessel 12/19/2023 at 07:430 Comments
Turns out that the bytes in the generated ASCII HEX files were "out of order" because the internal memory addresses of PicoRAM 6116 don't match the linear order of the physical address space. Well, the Microprofessor obviously doesn't care as long as the address (re-)mapping is consistent (and it was) - but once you export this "internally garbled" memory content to an ASCII HEX file all your bytes are out of order and you don't recognize your program any longer. And editing on the PC becomes impossible, of course.
So, I needed some masking and bit shifting before writing the HEX file - this is doing the trick:
  for (uint32_t b = 0; b < 2048; b++) {
    uint32_t i =
      ((b & 0b00000000000000000000000000100000) ? 1 : 0) << 0x5 |
      ((b & 0b00000000000000000000000001000000) ? 1 : 0) << 0x0 |
      ((b & 0b00000000000000000000000010000000) ? 1 : 0) << 0x1 |
      ((b & 0b00000000000000000000000100000000) ? 1 : 0) << 0x2 |
      ((b & 0b00000000000000000000001000000000) ? 1 : 0) << 0x3 |
      ((b & 0b00000000000000000000010000000000) ? 1 : 0) << 0x4 |
      ((b & 0b00000000000000000000000000000001) ? 1 : 0) << 0x6 |
      ((b & 0b00000000000000000000000000000010) ? 1 : 0) << 0x7 |
      ((b & 0b00000000000000000000000000000100) ? 1 : 0) << 0x8 |
      ((b & 0b00000000000000000000000000001000) ? 1 : 0) << 0x9 |
      ((b & 0b00000000000000000000000000010000) ? 1 : 0) << 0xA ;
    sdram[b] = ram[cur_bank][i];
The order of the bytes in the sdram array then matches the byte order in the physical address space and what is observed by the user with the MPF-1B monitor program. Hence, I can now write ASCII HEX files on the PC, using an assembler, or a simple text editor, in a natural way.
I have updated the firmware file in the files section here.
Also, I extended the ASCII HEX file format so that I can specify a start address (origin, via @<address> in the file), and partial HEX files are fine as well (i.e., you don't have to specify 2048 Bytes, fewer are fine - obviously, it would be super annoying of having to add hundreds of zero bytes just for padding your program to fill the memory). In addition, the reader is now accepting upper and lower case HEX characters (A-F, a-f), just to facilitate editing with a text editor on the PC (CAPS LOCK and HEX doesn't go together well, as you are losing the numbers with CAPS LOCK!)
Here are a few example programs illustrating the file format:
Simple Counter:
3e 00 3c f5 21 00 19 cd 78 06 f1 f5 dd 21 00 19
cd 24 06 f1 18 ec
Simple Counter with Sound starting at address 0x1900 (instead of default which is 0x1800):
@1900
cd 24 06 f1 f5 21 0a 00 4f cd e4 05 f1 18 e3 00
ASCII HEX saved by PicoRAM (full memory dump):
3E 00 3C F5 21 00 19 CD 78 06 F1 F5 DD 21 00 19
CD 24 06 F1 F5 21 0A 00 4F CD E4 05 F1 18 E3 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 19 01 19 86 06 1C 18 08 4D 00
00 B6 1F B7 1F 86 06 77 06 10 06 1B 06 E4 00 00
00 00 00 00 00 00 8F BA FD FD FF 70 00 00 00 00
9F 1F 00 00 00 00 00 00 00 00 00 00 00 18 00 18
FF FF FF 00 00 A5 00 00 00 00 FF F3 C9 00 66 00
55 44 2F 00 00 00 00 00 00 00 00 00 00 00 00 00
Note that the PicoRAM-generated HEX dumps always contain a few bytes at the end - these are the MPF-1B's monitor variables and Z80 stack!
