Current mode is working
A project log for PocketPD - USB-C Portable Bench Power Supply
Leveraging the Programmable Power Supply (PPS) of USB PD 3.0 and 3.1 to make an ultra-compact bench power supply
centylabCentyLab 03/02/2024 at 00:220 Comments
It requires some modification to the AP33772 Library but it seems like the current limit is working on our device.
Here you can see the current limit (small font) is at 1.3A and we are reading 1.32A. The voltage will change when you are in current limit mode. During this mode, the voltage encoder knob will not react if you increase the voltage as the voltage is capped by the current.
