A promising instruction sequence
A project log for Bootstrapping a ROMless Z80 using RS-232
Is it possible to bootstrap a simple ROMless Z80 system using only two wires - e.g. from an RS232 interface? This project explores this.
willstevenswill.stevens 01/10/2024 at 21:380 Comments
Consider this sequence of instructions:
DEC A
INC L
LD (HL),A
HALT
The binary codes for these are:
00111101
00101100
01110111
01110110
And the bits D7..D0 in this sequence  can be expressed as simple functions of the address bits:
D7=A2
D6=A1
D5=1
D4=A1 or /A0
D3=/A1
D2=1
D1=A1
D0=/A0
The consequence of running this are that the following sequence gets executed repeatedly (assuming that NMI and consequent jump to 66h occur after HALT is executed)
DEC A
INC L
LD (HL),A
HALT
RST 30h
This sequence fills 256 bytes of memory with a decreasing sequence of bytes (and also pushes values onto the stack when NMI occurs and when RST 30h is executed).
If the INC L instruction could be suppressed somehow during selected iterations of this sequence, then any desired sequence of bytes could be written to a block of 256 bytes of RAM.
There are a couple of questions to answer before this can be used as a bootstrap mechanism:
