First batch of PCBs arrived (thanks PCBWay)
A project log for MAX7219 8x8 LED module clone
The FC-16 module is a common 8x8 LED matrix utilising the MAX7219. This project is a DIY clone.
stephen-gStephen G 01/08/2024 at 10:420 Comments
My batch of PCBs arrived. This is my first time using PCBWay, so I was keen to see how they looked. I am quite happy with them and cannot identify any flaws visually (even after zooming in on a photo). I was convinced to try PCBWay because they contacted me offering to send a free batch of PCBs, so I took them up on the offer.
I've soldered up a module but so far, things are not looking great - when I apply power, every LED lights up. I've already checked the connection on the PCB itself, so either:
More investigation is required.
I will most likely use PCBWay again. The prices and quality are not much different from JLCPCB, but PCBWay has the following advantages:
When I first started ordering PCBs, it was different - PCBWay delivery was the same for both, and JLCPCB's manufacturing fee was cheaper. So I started sending the finished boards to my sister-in-law in Melbourne and waiting a few weeks until I could get them from her. But now that I've tried PCBWay and got the PCBs delivered directly for the same price, I will definitely continue to use them.
Below you can see the excellent quality of the PCBs. My LED module PCB is on the left. On the right is a different project that is more complicated and uses ICs with finer pitch leads. I could not find any flaws (only some dust!).
