Battery Emulator
This software enables EV battery packs to be used for stationary storage in combination with solar inverters
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Want to reduce your electricity bill? Want to be more self sustainable? Want to go offgrid? If you answered yes to any of these questions, this project is for you!
The Battery-Emulator project started as a way to emulate expensive brand batteries for locked eco-systems. It has now evolved to support >20 different inverters, and >10 different EV battery brands.
To put it simple, the Emulator is placed between an EV battery, and an inverter, and acts as a translator. This way you can power your home, in a true plug'n'play fashion. Check out the Github link below for the source code, and an extensive Wiki section!
https://github.com/dalathegreat/Battery-Emulator
