PVC Tube
A project log for Gentle Typing Trainer
Uses piezo sensors under your keyboard to sense harsh typing and warns you with the flash of a LED. Helps to guard against OOS.
chrisChris 03/10/2024 at 00:460 Comments
I cut the PVC tube to match the width of my keyboard (256mm), then drilled the following holes:
I sprayed the tube with matt black enamel paint to match my keyboard. Some pictures:
