Step 1 - Solder and verify
A project log for KS Zigbee Gateway
My own Zigbee Gateway with speaker output for realtime audio notifications, with MQTT support and more
h4rdc0derh4rdc0der 02/08/2024 at 21:420 Comments
The board has been assembled to test the circuit's functionality. Zigbee module was mounted on the board right after DAC verification.
The most challenging part was soldering the DAC chip and then, a bit easier was USB-C soldering.
Quick examination confirmed correct voltage generation, DAC functioning, but noise during playback startup.
Here's a little demo:
