Step 3 - Running up the stack
A project log for KS Zigbee Gateway
My own Zigbee Gateway with speaker output for realtime audio notifications, with MQTT support and more
h4rdc0derh4rdc0der 02/09/2024 at 15:450 Comments
Looks like I'm on a good streak!
After many hours of debugging all the stuff, I managed to fix audio issue in external library (https://github.com/schreibfaul1/ESP32-audioI2S/issues/626). Now the audio startup noise is gone.
I've also ordered smart bulb, which paired flawlessly. Check this out!
