I've got the Jetson Nano running! Partially...
A project log for Kevin - Robot Companion For Makers
A hexapod robot companion, that gets tools for you and reminds you to put them back. Also cute.
christian-koschmiederChristian Koschmieder 03/04/2024 at 21:220 Comments
After some more tries and checking the SD Cards twice, I tried using an older image of JetPack. Version 4.5.1 to be exact. This version installs correctly and after some minutes of install-duties it greeted me with a working LXDE desktop!
"So, what's next", I thought. "Surely it should be easy to connect one of my two Raspi-Cameras to the CSI-port and just have that displayed."
Well, there is a short guide to do exactly that. Sadly, my camera seems not to be supported. At least not out-of-the-box.
Connecting it was relatively easy but when starting the capture command it just spat out a lot of command line information and then an error message telling me that there seems to be no camera.
I will have to see why that is, but for now it's off to bed.
