Wooden 8020 / V Slot maker
03/18/2017 at 07:09 • 0 commentsThis is an animation of a V slot maker that uses wood instead of aluminum. The Idea is you can quickly prototype with wood and then switch to aluminum if necessary use. It makes 20mm V slot out of 1in square wood. (914.4mm) 36 in. x 1 in. Hardwood Square Dowel is $3.42 Home Depot vs 1000mm 20mm 20mm vSlot $20.28 with shipping.
laser cut NEMA 17 mockups
03/17/2017 at 20:00 • 0 commentsWe laser cut NEMA 17's so we can use them to figure of fixtures and clearances.
machining at Supplyframe Design Lab
03/07/2017 at 11:23 • 0 comments -
Linear Rail
02/28/2017 at 08:48 • 0 commentsThe plan is to use this Linear Rail design for almost all steps of the folding operation. We can easily change the length of the rail by cutting the V-slot, and using a shorter Ballscrew. The clear plastic piece is the standard base for the 3D printed box-interface-parts. Its removable from the cart with 4 bolts. The cart is built on a single 1/8 metal base plate that requires no bending. The plate that the stepper bolts to with the long brass stand off's is also flat 1/8 in metal with no bending. Meaning If we order a large batch form the machine shop it comes out to only a few dollars a piece if cut with high power laser. >=D we plan is order a large batch of these plates and sell the rail kit on Amazon for people who would like to make their own.
1x NEMA 17 steper
1x 250mm 8mm BallScrew
1x 250mm V-SLOT rail
4x V-slot Wheels kit
4x 40mm m3 standoffs
1x stepper ball screw coupler.
2x 1/8th plates
and all the hardware.
Thanks -Jake C -
Locking tab update
02/11/2017 at 21:40 • 0 commentsAfter a successful test we change design because we need a stronger and more constant mechanism.
I just finished 3d printing the part
It's Alive!!!
02/09/2017 at 07:23 • 0 comments -
Motor and Labview tests
01/30/2017 at 19:55 • 0 comments* just fixed Video Links. :)
Testing the difference between continuous servos and Steppers using LabView
Interface design
01/30/2017 at 16:54 • 0 commentsThis is a design made in LabView to see what functions we would need in the robot
Video of folding Operation.
01/29/2017 at 07:51 • 1 commenthere we have the advanced video of the folding operation with included chassis structure.
linear stages
01/26/2017 at 06:44 • 0 commentsStarting to design to Linear stages. so far we have two designs that cost only 25$ in parts to make. we also started assembling a parts tools storage for all the nuts and bolts the project will need.
