Soldering... getting closer
A project log for Modular Pi Cam
A Raspberry Pi based camera that can swap body parts and camera modules
jacob-david-c-cunninghamJacob David C Cunningham 03/13/2024 at 20:370 Comments
The front plate takes almost 10 hours to print... so I'm waiting on that.
I soldered all the parts together, tested the buttons all work
Tested LCD
This is my last day off so won't be able to take it out till next week Monday
I will reprint the back plate... this one took 4 hours but if rotated so it has the nicer finish takes over 7.
I figure as something I will look at a lot, should look better
The internals are nasty... took me over 2 hours to solder this
Trying out lenses at the park
