Proof-of-concept experiment
A project log for Claymore - SLS 3D printer using polymer clay
SLS 3D printer using paste material (polymer clay) instead of powder for home use.
satoshi-tanakaSatoshi Tanaka 03/16/2024 at 01:100 Comments
In the beginning of this year (Jan. 26), before building anything, I did a small experiment to confirm the most important idea of this project: hardening polymer clay with laser.
Methods
The materials are:
The small amount of clay was kneaded and stretched into thin layer of about 1 mm.
Then the small area on clay was irradiated with laser, in a manner similar to filling an area with pen.
The laser power (PWM input) was set to 100%.
Results
The irradiated area became hard rubber-like state, and it was not easily teared apart when pulled.
Therefore, it is proven that polymer clay can be baked with laser.
However, the process generated terrible odor. Safety of this process has to be investigated further.
