Hot off the press
A project log for Pocketbone KiCAD
Smalls mint tin sized BeagleBone (KiCAD version)
michael-wellingMichael Welling 02/25/2017 at 18:337 Comments
This week I happened to be in Portland for the Embedded Linux conference so I had a chance to pick up boards directly from OSH Park.
Here is a picture of a few of the boards taken at the OSH Park home office:
Here are a few more pictures now that I am back home.
As you can see some of these boards are still partially connected. The "mouse bite" connections are required to combine them with several other PCBs in a large panel. I got to see a sample panel and the CNC routing is quite elaborate.
The silkscreen is impressively accurate. This is done using a special process that essentially adds another layer of soldermask of a different color.
As you can see the boards fit the tins as expected. Probably going to be a bit tricky to get the holes in the tins for the USB and MicroSD connectors.
Overall a very nice board. Thanks OSH park!
If you want a chance to see a few of these bare PCBs in person (and happen to be going), I will be at Scale15x in a Pasadena next week. Catch them at the Beagleboard.org exhibition booth.
Dave's Dev Lab wrote 02/26/2017 at 00:05 point
did you order your stencil yet?
Michael Welling wrote 02/26/2017 at 00:44 point
Not yet Dave. Any last minute recommendations? Besides not soldering BGAs in a toaster oven at home. :)
davedarko wrote 02/25/2017 at 22:02 point
No banana for scale though :( Good luck with soldering that - I tried an I2S microphone the other day... with 5 pins of that size, I wouldn't dare soldering that BGA chip :) nice work.
Michael Welling wrote 02/26/2017 at 00:53 point
Sorry out of bananas. I will post the next best thing. A lineup of it, the beaglebone black and C.H.I.P.
davedarko wrote 02/26/2017 at 03:41 point
thank you :)
AVR wrote 02/25/2017 at 21:53 point
very nice! looking froward to the soldering and testing!
Michael Welling wrote 02/26/2017 at 04:01 point
Thanks!
