Attempt to reduce power draw
A project log for ML Clip Cam
This is a much smaller version of the previous project which the next phase is an autozoom, moving camera on a tripod paired with IMU on hat
jacob-david-c-cunninghamJacob David C Cunningham 04/16/2024 at 03:000 Comments
Well... idk if this is a pointless thing to do since later I will have to undo it anyway (speed up CPU again).
I went from 240MHz to 10MHz that did help with power consumption.
I also added auto-dimming to the LCD after 5 seconds of no touch input.
