Motor Fun
A project log for Wobble
Egg shaped kid's toy that wobbles
krockwellKrockwell 03/31/2024 at 01:090 Comments
The motor drive circuit is working! Here's a snapshot of the setup. I can easily control the speed using the arduino sketch. The DRV8825 gets very hot during operation so I'll need to make sure I am heatsinking that properly.
I also created a small lever arm for the motor and installed it in the egg with some weights (quarters). The egg did wobble when I ran the motor which is a good sign but I need to make some adjustments to improve it:
Next Steps:
