Introduction
It's the perfect time of year to stay warm and cosy with a hot cup of tea or coffee. However, it's important not to make it too hot as it may burn your mouth. That's why I made a Temperature Monitoring Smart Coaster. This smart coaster can monitor the temperature of your beverage in real time and notify you when it's at a drinkable temperature. You can easily customise the temperature range using the provided code.
The current setting in the code is
Less than 50c = Cooled
50c - 70c = Drinkable
Grater than 70c = Too hot
We are using the Infrared Temperature Sensor GY-906 MLX90614 to sense temperature. The results will be displayed on a small OLED screen. All of these components are controlled by the Seeed Studio XIAO SAMD21. Most parts of this project were created using 3D printing technology. If you're interested, I can show you how it was constructed.
Supplies
Parts
Tool
Step 1: Modeling in Autodesk Fusion 360
I used Fusion 360 for planning and designing this, but I am not fully getting into how I modelled it, we will look at how I exported the laser-cut metal parts of this project, and we will discuss it in the next step, you can skip this step if you need. all design files are given below
Step 2: Exporting laser-cut DXF files from the Fusion 360
Step 3: Preparing the top plate
After receiving the aluminium part, we need to sand both sides with 120 grid sandpaper slightly.
After sanding we need to spray paint it 2 cotes and leave it to dry
Step 4: 3d printing parts
We also need to 3d print some parts for this project. i printed mine with my anycubilc Kobra 2 neo 3d printer .all files are available at Step 1
Step 5: Uploading Code to XIAO
I always like to upload the code to the microcontroller before assembly. I am using Arduino IDE for flashing the code. follow these tutorials for setting up IDE for Seeed Studio XIAO SAMD21 and learn more about this board
Please download and install the Adafruit_MLX90614.h library before compelling
How to install library tutorial video link
The code
#include <Wire.h>
#include <Wire.h>
#include <Adafruit_MLX90614.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //Declaring the display name (display)
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
static const unsigned char PROGMEM image_weather_temperature_bits[] =
{0x1c,0x00,0x22,0x02,0x2b,0x05,0x2a,0x02,0x2b,0x38,0x2a,0x60,0x2b,0x40,0x2a,0x40,0x2a,0x60,0x49,0x38,0x9c,0x80,0xae,0x80,0xbe,0x80,0x9c,0x80,0x41,0x00,0x3e,0x00};
static const unsigned char PROGMEM image_weather_frost_bits[] =
{0x01,0x00,0x13,0x90,0x31,0x18,0x73,0x9c,0x09,0x20,0x05,0x40,0x53,0x94,0xfe,0xfe,0x53,0x94,0x05,0x40,0x09,0x20,0x73,0x9c,0x31,0x18,0x13,0x90,0x01,0x00};
static const unsigned char PROGMEM image_hand_thumbs_up_bits[] =
{0x00,0x10,0x00,0x28,0x00,0x28,0x00,0x48,0x00,0x50,0x00,0x90,0x01,0x3e,0xfa,0x03,0x8c,0x05,0x88,0x03,0x88,0x05,0x88,0x03,0x88,0x05,0xa8,0x02,0x8e,0x06,0xf9,0xfc};
static const unsigned char PROGMEM image_operation_warning_bits[] =
{0x00,0x00,0x01,0x80,0x02,0x40,0x02,0x40,0x04,0x20,0x09,0x90,0x09,0x90,0x11,0x88,0x11,0x88,0x21,0x84,0x40,0x02,0x41,0x82,0x81,0x81,0x80,0x01,0x7f,0xfe,0x00,0x00};
void setup() {
mlx.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //Start the OLED display
display.clearDisplay();
display.display();
void loop() {
  float coffeeTemperature = mlx.readObjectTempC();
  if (coffeeTemperature < 50) {
    display.setTextSize(2);
    display.setTextColor(SSD1306_WHITE);
    display.drawBitmap(105, 9, image_weather_frost_bits, 15, 15, 1);
  } else if (coffeeTemperature >= 50 && coffeeTemperature <= 70) {
    display.drawBitmap(105, 6, image_hand_thumbs_up_bits, 16, 16, 1);
  } else {
   display.drawBitmap(105, 7, image_operation_warning_bits, 16, 16, 1);
  display.drawBitmap(65, 9, image_weather_temperature_bits, 16, 16, 1);
  display.drawCircle(115, 16, 21, 1);
  display.setCursor(1, 10);
  display.print(coffeeTemperature);
  display.display();
  delay(500);  // Update every second
void setup() {
mlx.begin();
display.display();
void loop() {
  } else {
  display.display();
Step 6:Wiring Diagram
It is a simple circuit
  1. D4 of xiao to SDA of OLED and GY-906
  2. D5 of xiao to SCL of OLED and GY-906
  3. 3v3 of xiao to VCC of OLED AND GY-906
  4. GND of xiao to GND of OLED and GY-906
Step 7: Assembly and Wiring
We can start with the sensor mount Assembly
Step 1
Solder four 8cm wires into the GY-906 `
Step 2
Push in the GY-906 into the 3d print
Step 3
Run the wires through the hole in the mount back cover
Step 4
Snap in the back cover
Step 5
Screw in sensor mount with two M3 10mm screw
Step 6
Run the sensor wires through the centre hole into the main body. Twist the wires a little bit
Step 7
Solder sensor wires into Xiao
Step 8
To connect the OLED terminals, you need to solder four wires with a length of 14cm each.
Step 9
Align the OLED display with the 3D print's viewing window and glue it in place.
Step 10
solder the wires of the OLED into the Xiao.
Step 11
Insert the xiao into the 3D print, aligning it with the opening for the USB-C port. Secure it in place with glue if necessary.
Step 12
Attach the 3D-printed back plate by screwing it in with four M3*10mm screws.
Step 13
Slide in the top aluminium plate
We just completed the assembly
Final Thought
I hope it is a useful full project. also, more likely l love that I can design something that looks good. I am so happy to find out how the aluminium and 3d print can come together. You can customize the temperature range on the code easily. Also, it will only work with cups that have good thermal conductivity.i think it will look good on my dusk
