Half Bridge Driver
A project log for Toyota Camry Hybrid Glow up To Save The World
That's right, the Toyota Camry Hybrid is going to save the world. Don't believe me, follow along as an old 2007 transforms into awesome.
sciencedude1990sciencedude1990 04/25/2024 at 03:220 Comments
Built a half-bridge driver based on the MPS MP18021.  I like the MP18021 because the SW pin is tough.  It can go to -5 V, in case there is something pulling down the switch voltage.  Also, it has the diode built in for the VDD to BST path, so that saves a part.
I drove the INH and INL from a raspberry pi pico (PIO programmed), and tested it with 2 Ohms of resistance.  The 8x8 powerpak transistors have quite a lot of gate capacitance, so you can drive a few hundred kHz, but beyond that the MP18021 starts getting kind of warm.  A few MHz and it will go into thermal shutdown.
I am debating a full bridge versus a flyback design for the DC/DC converter, and I think I'll probably go with the flyback, but building the half bridge is kind of fun since you can re-purpose them for other projects like motor drivers.  At the bottom was a TC620CVOA for checking the board temperature, and that worked as expected.  It is a super simple chip - if the temperature passes a setpoint, it outputs a voltage.  That is the third wire going to the raspberry pi pico for monitoring (the TC620VCOA is powered from 12 V, so there is a voltage divider at the output to match with the 3.3V of the pico).
