What is the Mg-Bi composite?
A project log for Bi-Mg Laminates
We demonstrate that Art's Parts, recieved at Coast to Coast Radio, are in fact easy to reproduce with human technology
michael-perroneMichael Perrone 03/22/2024 at 18:482 Comments
Being relatively well-versed in metallurgy and to some extent chemistry, quite a few conventional explanations come to mind when I think of the magnesium-Bismuth composite
But let's assume for a second that perhaps the composite was damaged by re-entry, weaponry or the crash-landing so it is not in its pristine state. It's certainly possible that the outermost Bismuth layer could have evaporated off in that scenario, and the magnesium could have been scarred in the way shown. What else might it be then?
If the material really is of alien or time-travelling AI origin, then it may be useless to speculate what the application may have been: in all likelihood they would be too far ahead technologically for us to be able to formulate relevant hypotheses. Nevertheless, whatever the Mg-Bi composite is, with this Hackaday article, everyone will now have the capability to explore its material properties for themselves, and hopefully we can crowdsource a reasonable answer.
Well those are my thoughts on the matter; what do you think the Mg:Bi composite is?
Brian wrote 03/29/2024 at 00:25 point
Also- Since you mentioned Terahertz, this layered structure reminds me of the layering of an anti-reflection (or high reflection) coating. The alternating (effective) refractive index of the materials (heavily dependent on wavelength) could create either a Bragg reflector, or by smoothing the refractive index difference between the air and the material this structure was applied to, could reduce the reflection.
For reflectors, structures like this can even be used for X-ray reflectors. https://physicsopenlab.org/2018/01/18/bragg-diffraction/
Michael Perrone wrote 03/29/2024 at 01:34 point
Good thought Brian! It is possible it is a bragg grating of some king - perhaps it may even be an alternative to the beryllium reflectors used in gamma ray telescopes, but maybe that's a long shot. Now that we have the ability to make these though, we can test the material and see for ourselves.
