Dev Update #1
A project log for ddbot, a mobile robot for AI & robotics education
A user-friendly platform for students and hobbyists to learn and build robotic applications using AI techs.
triplel-roboticsTripleL Robotics 03/24/2024 at 23:260 Comments
This is the first log of this robot project, temporally named "ddbot", which is a ground robot with differential-drive kinematics. This robot is going to be our first product and serves as a testbed for subsequent development.
Progress: what we have done is to design and build up the first layer of chassis for the robot, as shown below.
first layer
        first chassis layer
We 3D print the base to support the battery, motors, and connectors. Right now the 1800mAh LIPO battery is used and we will see if it can last long enough for the applications. DC gearbox motors are used. Two main wheels and one universal caster wheel (in the front, below the base) are used for differential drive mode.
universal wheel
        universal wheel
Plan: next, we try to set up the second layer of the chassis, adding the motor control board and an MCU for low-level control. Stay tuned...
