13/03/2024
We defined project goal
Found a 3D model similar to our need for the hanger and the gear ratio.
Defined the structure of the project (Individual motor and gear system for the direction) front unpowered and fixed wheels.
20/03/2024
We created a one note containing all the research in an organized way with different links for each part of a regular skateboard. it includes all the different types of variables that a board could have from the wheel to the technical part like the remote control. It also has technical data and tutorials.
https://esmefr-my.sharepoint.com/:o:/r/personal/loris_le-roy_esme_fr/_layouts/15/Doc.aspx?sourcedoc=%7B70916AA8-734F-4E57-82C3-2169487C08AB%7D&file=Loris%20%40%20ESME&action=edit&mobileredirect=true&wdorigin=Sharepoint&RootFolder=%2Fpersonal%2Floris_le-roy_esme_fr%2FDocuments%2FLoris%20%40%20ESME&d=w70916aa8734f4e5782c32169487c08ab&csf=1&web=1&e=cfE6oN&cid=7b6252d9-3ada-4d58-96d4-e0ba3a71f80a
We then made an arduino basic circuit containing a bluetooth reveicer and a servo motor.
